Group: DynoMotion Message: 9375 From: daveymahomh600e Date: 3/28/2014
Subject: Worn Out Initialization Program
Okay, I know they don't wear out, but something went "sproing" yesterday and I can't figure it out.
I have a KFLOP/SnapAmp lathe and while I was moving the slide around it stopped moving in one axis. I thought the axis had faulted because it wasn't near a limit, but it was pushing hard. I tried to run the initialization c program in KMotionCNC but it wouldn't zero. I then tried running it using KMotion save, run, download,etc. button but it wouldn't complete. I then tried an older file with a few less items and a different name nad it worked fine. After running it the axis were working as expected. I then went back and tried the first file again, but still no go. It seems almost like it is corrupted, but it re-compiles each time the KMotion routine runs, does it not? Is there a rogue file somewhere that needs to be deleted?
Thanks for your help,
David.
Group: DynoMotion Message: 9376 From: Tom Kerekes Date: 3/28/2014
Subject: Re: Worn Out Initialization Program
Hi David,
Yes the C programs are re-compiled every time.
I would compare the program that works and the one that doesn't.  WinMerge.org is a great free program for comparing files.
Or add printf statements to determine what in the initialization is not successfully completing
Or post the two programs for us to look at.
